1 | initial version |
This is ultimately just an HTML file, that can be shared and opened in any browser. You can also save that HTML page in PDF format from your browser.
If your model is called "model.osm", you will have a folder model/run
and then find the subfolder in which you will find the results HTML file, typically model/run/6-UserScript-0/report.html
(the leading number could be something other than 6)
