Since your fan schedule is called "Always On Discrete," I think that is the problem. You wan the fan schedule to be off at night, then the availability manager overrides the fan schedule to turn the air handler back on for a night cycle.
Since your fan schedule is called "Always On Discrete," I think that is the problem. You wan want the fan schedule to be off at night, then the availability manager overrides the fan schedule to turn the air handler back on for a night cycle.
