I wonder if your zone sizing has a high enough supply temperature. My guess is that this might not be high enough, maybe try raising that, as a rule of thumb I use a supply temperature difference of 11C, which would be 31C in this case, if you already have that maybe try running it with 35C to see if it makes a difference. Also how is your ventilation air coming into the zone, is it from a seperate AHU or through the VRF? If it is through a separate AHU check that the temperature setpoint on the heating coil here is high enough.
