If you're using WaterHeater:Mixed
there is no surface area of the tank it doesn't have a defined shape, just a volume. If you're using WaterHeater:Stratified
then Tank Height
and Volume
are input parameters and you can calculate a surface area from that. I'm not entirely sure what use you have for it though since the loss-coefficients are independent of surface area.
![]() | 2 | No.2 Revision |
there is no surface area of the tank as it doesn't have a defined shape, just a volume. If you're using WaterHeater:Stratified
then Tank Height
and Volume
