Construction and schedule sets applied at the building level do apply to all spaces, there is no need to set them at lower levels unless you want to override the building level defaults.
The "Apply Space Attributes" tool in the SketchUp plug-in will allow you to apply ideal air loads to every zone in your model. Just select all of your spaces before you run the tool.
