It is hard to say why your windows are not being created correctly. You might try opening the SketchUp Ruby console and watching for errors as you try to draw the windows. It is also a good idea to open SketchUp then open the OSM directly, do not use the linked SKP file. Finally, undo operations often fail so it is best to not use undo.
This video describes how to create an air wall.
