Hi.
I use a interface of Energy Plus (Design Builder).
Design Builder include a internal calculation engine for CFD calculations.
You can export the airflownetwork results and radiant temperature results of E+, and use it as limit condition inputs.
Then you make a CFD simulation and can view Airflow between zones in EnergyPlus
Hi.
I use a an interface of Energy Plus (Design Builder).
Builder). Design Builder include a includes an internal calculation engine for CFD calculations.
calculations. You can export the airflownetwork results and radiant temperature results of E+, and use it them as limit condition inputs.
inputs. Then you can make a CFD simulation and can view Airflow between zones in EnergyPlusEnergyPlus.
