You should be able to drag the construction from the library in the 'Constructions' tab in the OS application.
If it's not there try loading another example model via File->Load Library or in the SketchUp plugin using the 'On Demand Template Generator' script.
If it's not there try loading another example model via File->Load Library or in the SketchUp plugin using the 'Space Type and Construction Set Wizard' script found under 'On Demand Template Generator' script.Generators'.
