DesignBuilder is very visual and easy to use, you can run the complete simulation without export the file to EnergyPlus,
with detailed HVAC system you can have a template for the 8 systems - baseline Appendix "G",the HVAC and building 3D models are simulated simultaneously to ensure the dynamic interaction between the building and systems is treated accurately.
Comprehensive Ground Source Heat Pump, Underfloor air distribution, Dedicated outside air systems, and other systems have been added recently to version 4.
