    |  1 |    initial version    |
The climate zone object in OpenStudio doesn't directly affect the EnergyPlus simulation, however it is used by many measures to determine what construction properties should be applied. There are other non ASHRAE climate zones, but the OpenStudio Application only supports ASHRAE and CEC (California Energy Commission) however the API for the Openstudio Climate Zone object would support any custom climate zone.
