1 | initial version |
I'm not sure where this is used in E+ anymore, adding simple windows maybe? The problem is under defined in the case of horizontal surfaces, here is the algorithm OpenStudio uses. We ran across the same difficulty defining azimuth for horizontal surfaces in gbXml output, it would be nice to standardize on an approach.
