It appears that when you call addToThermalZone on the HPWH, OpenStudio assumes sets the compressor location, etc, to be zone-based. This seems to happen here in the source code.
To fix this, try moving the line hpwh.addToThermalZone(zone) into the else block.
It appears that when you call addToThermalZone on the HPWH, OpenStudio assumes sets the compressor location, etc, to be zone-based. This seems to happen happens here in the source code.
It appears that when you call addToThermalZone on the HPWH, OpenStudio assumes sets the compressor location, etc, to be zone-based. This happens here in the source code.
To fix this, try moving the line hpwh.addToThermalZone(zone) into the block.elseif
