I think that error indicates a coding problem that you will not be able to get around by editing the IDD. You might send the input file to the energyplus helpdesk so the developers can follow up.
In looking at the code, I think you could add in any type of a schedule input object that has 5 or more alpha input fields and that will serve as a workaround for this issue. This is because the "AlphaArg" array sizes should be dynamic and adjust to the longest schedule input object.
