This should do what you want. It's based on something I used for preparing IDFs for jEPlus.
import fileinput
def edit_idf(substitutions, idf_path):
Replace items in an IDF in place (this changes the file directly so be careful).
Parameters
substitutions: dict
A dictionary mapping the variable to be substituted to the value
to be substitute in its place, e.g. {'Block*:': ''}
will replace 'Block:' with '' in the input file.
idf_path : str
The path to the IDF or IMF.
for key in substitutions:
for line in fileinput.FileInput(idf_path, inplace=True):
for s in substitutions:
line = line.replace("%s" % s, str(substitutions[s])) # enforce str
print line,
import fileinput
Parameters
substitutions: dict
will replace 'Block:' 'Block*:' with '' in the input file.
idf_path : str
print line,
import fileinput
Parameters
substitutions: dict
will replace 'Block*:' with '' in the input file.
file. You may also use regular
expressions so {'Block[\d+]:': ''} would replace 'Block1:', 'Block2:',
'Block999:', etc.
idf_path : str
line = line.replace("%s" re.sub("%s" % s, str(substitutions[s])) # enforce str
s), str(substitutions[s]), line)
print line,
Your substitutions dict should be:
subs = {r'Block[\d+]': ""}
| 4 | No.4 Revision |
import fileinput
import re
Parameters
substitutions: dict
will replace 'Block*:' with '' in the input file. You may also use regular
'Block999:', etc.
idf_path : str
line = re.sub("%s" % s), str(substitutions[s]), line)
print line,
| 5 | No.5 Revision |
This If you do want to use eppy (and I would recommend it!), @santoshphilip's answer is the way to go.
However, if you want an option that doesn't use eppy, this should do what you want. It's based on something I used for preparing IDFs for jEPlus.jEPlus.
import fileinput
import re
Parameters
substitutions: dict
'Block999:', etc.
idf_path : str
line.rstrip())
print line,
| 6 | No.6 Revision |
import fileinput
import re
Parameters
substitutions: dict
'Block999:', etc.
idf_path : str
line = re.sub("%s" % s), str(substitutions[s]), line.rstrip())
print line,
| 7 | No.7 Revision |
If you want to use eppy (and I would recommend it!), @santoshphilip's answer is the way to go.
However, if you want an option that doesn't use eppy, for example if you want to use regular expressions in your search, this should do what you want. It's based on something I used for preparing IDFs for jEPlus.
import fileinput
import re
Parameters
substitutions: dict
'Block999:', etc.
idf_path : str
print line,
