I normally put a dehumidifying schedule at the ZoneControl:Humidistat level. The value I use is 50-60%. On the AHU side (if it is a unitary system object), you will need to specify the type of latent load control (only when sensible load is available etc.), and dehumidification control type (none, coolreheat, etc.). For humidity schedule, I just put in 30% schedule. This will come into effect only if you have a humidification object.
