For the first question, you can create a second IDF and add the extracted objects to it.
surfaces = idf.idfobjects['BUILDINGSURFACE:DETAILED']
windows = idf.idfobjects['WINDOW']
idf2 = IDF()
idf2.new()
for s, w in zip(surfaces, windows):
idf.copyidfobject(s)
idf.copyidfobject(w)
For the second question, IDF.saveas() is just to change the filename. It doesn't really make sense to save it as a CSV since each object has different fields. I suppose you could do something like:
with open('out.csv', 'w') as f_out:
f_out.write(','.join(str(i) for i in headers) + '\n')
for row in rows:
f_out.write(','.join(str(i) for i in row) + '\n')
Alternatively you could open up the IDF in the OpenStudio SketchUp plugin to get a visualisation of the surfaces and windows in the model.
idf2 = IDF()
idf2.new()
idf2.copyidfobject(s)
idf2.copyidfobject(w)
for row in rows:
# get the geometry objects
# make a new empty IDF
idf2 = IDF()
idf2.new()
# copy the geometry objects into the new IDF
# save the geometry as an IMF for use by EPMacro
idf2.saveas('geometry.imf')
for row in rows:
| 4 | No.4 Revision |
idf2 = IDF()
idf2.new()
headers = surfaces[0].objls # get the column headers as a list
rows = [s.obj for s in surfaces] # get the values as a list of lists
for row in rows:
| 5 | No.5 Revision |
idf2 = IDF()
idf2.new()
for row in rows:
In response to your comment, you need to tell eppy which output variable you want to remove from the IDF. The simple case first:
# to remove them all
for variable in idf.idfobjects['OUTPUT:VARIABLE']:
idf.removeidfobject(variable)
Removing a specific variable can be a bit tricky though. Since they don't have a Name field we can't select them using idf.getobject('OUTPUT:VARIABLE', name). They do have a Key_Value field, though this is often *, and a Variable_Name field. We can use those in a list comprehension to filter out the variable or variables to remove.
# to remove all variables of a given Variable_Name
name = "Electric Equipment Electric Energy"
variables = [v for v in idf.idfobjects['OUTPUT:VARIABLE'] if v.Variable_Name == name]
for variable in variables :
# to remove variables with a given Variable_Name with a specific Key_Value
key_value = "PrimaryHeater"
name = "Boiler Gas Energy"
and v.Key_Value == key_value]
