I have a couple of questions for you first:
I have a couple The simple answer is "yes", Radiance can be used to compute DGI -- at least, it can provide high dynamic range images for inspection to derive DGI. This paper details the derivation of questions for you first:the metric, and discusses its limitations as well.
Your workflow for using Ecotect would be to generate hemispherical fisheye view renderings of your design with Radiance, and apply the mathematical basis on them, or (easier) use evalglare to interrogate the HDR images and give you DGI (evalglare will also give you DGP and a host of other metrics as well).
BTW, Evalglare is most likely going
to
