Other option is using an alternate software for simulation, i suggest Ecotect because has a great graphical interface and it works with Radiance too, but an simulation work with Ecotect will have much less accuracy in comparation with the actual accuracy and validation of the results obtained using EnergyPlus.
Other option is using an alternate software for simulation, i suggest Ecotect because has a great graphical interface and it works with Radiance too, but an simulation work with Ecotect will have much less accuracy in comparation with the actual accuracy and validation of the results obtained using EnergyPlus.the core simulation EnergyPlus and their graphical interfaces like OpenStudio and DesignBuilder.
