If installing it to your %HOMEDRIVE% isn't working, try this:
1. Make an Environment Variable called GEM_PATH with the Value C:\Ruby200-x64\lib\ruby\gems\2.0.0
NOTE this does not point to your Home directory, but your Ruby installation
2. Download the source code or clone the source code using Git.
3. In a command prompt, navigate to the openstudio-standards/openstudio-standards directory of the source code.
4. gem build openstudio-standards.gemspec ENTER to build the gem.
5. gem install openstudio-standards-0.1.4.gem ENTER to install the gem. NOTE: You may get a warning message about the path in this step. Ignore this message.
1. this:
openstudio-standards/openstudio-standards directory of the source gem build openstudio-standards.gemspec ENTER to build the gem install openstudio-standards-0.1.4.gem ENTER to install the gem. NOTE: You may get a warning message about the path in this step. Ignore this message. | 3 | No.3 Revision |
C:\Ruby200-x64\lib\ruby\gems\2.0.0NOTE this does not point to your Home directory, but your Ruby installation
openstudio-standards/openstudio-standards directory of the source code.gem build openstudio-standards.gemspec ENTER to build the gem.gem install openstudio-standards-0.1.4.gem ENTER to install the gem. NOTE: You may get a warning message about the path in this step. Ignore this message.
