I don't believe there are limits on the air temperatures but there are limits on the surfaces temperatures. Here the air is being heated by the surfaces so those are the limits that matter. The default surface temperature upper limit is 200C, but this can be changed on input using the HeatBalanceAlgorithm object's input field called Surface Temperature Upper Limit.
