Are the split systems split AC units that have no heating? If you are you can use a PTAC and turn off the heating by setting the rated capacity and maximum water flow rate of the heating coil to zero.
Another option is to build an air loop with a "Unitary - Single Speed DX cooling - Cycling - Elec reheat" and turn off the electric reheat.
