@adhilton, this EMS code isn't too different from yours. The model this was used on has PlantComponent:TemperatureSource object on the demand side, and then cooling and heating water to air heat pumps on the demand side.
Here is the full run section of the measure that add's EMS code wasn't modeling infinite capacity. You could modify this to use the ES code from your answer.
# use the built-in error checking
if !runner.validateUserArguments(arguments(workspace), user_arguments)
return false
end
# reporting initial condition of model
runner.registerInitialCondition("The building started with #{workspace.objects.size} Energy Management objects.")
# Get the last openstudio model
model = runner.lastOpenStudioModel
if model.empty?
runner.registerError("Could not load last OpenStudio model, cannot apply measure.")
return false
end
model = model.get
plant_component_temperature_source = model.getPlantComponentTemperatureSources.first
inlet_port = plant_component_temperature_source.inletModelObject.get # todo - confirm this exists
schedule = plant_component_temperature_source.sourceTemperatureSchedule.get # todo - confirm this exists
string_objects = []
string_objects << "
Output:Variable,
#{inlet_port.name}, !- Key Value
System Node Temperature, !- Variable Name
Hourly; !- Reporting Frequency
string_objects << "
Ground_HX_Inlet_Temp, !- Name
#{inlet_port.name}, !- Output:Variable or Output:Meter Index Key Name
System Node Temperature; !- Output:Variable or Output:Meter Name
string_objects << "
EnergyManagementSystem:Actuator,
Ground_HX_Schedule_Actuator, !- Name
#{schedule.name}, !- Actuated Component Unique Name
Schedule:Constant, !- Actuated Component Type
Schedule Value; !- Actuated Component Control Type
string_objects << "
Ground_HX, !- Name
SET Tin = Ground_HX_Inlet_Temp, !- Program Line 1
IF Tin < 15.556, !- Program Line 2
SET Tout = Tin + 5.556, !- Program Line 3
ELSE, !- Program Line 4
SET Tout = Tin - 5.556, !- Program Line 5
ENDIF, !- Program Line 6
SET Ground_HX_Schedule_Actuator = Tout; !- Program Line 7
string_objects << "
Ground HX, !- Name
InsideHVACSystemIterationLoop, !- EnergyPlus Model Calling Point
Ground_HX; !- Program Name 1
# add all of the strings to workspace
string_objects.each do |string_object|
idfObject = OpenStudio::IdfObject::load(string_object)
object = idfObject.get
wsObject = workspace.addObject(object)
end
# report final condition of model
runner.registerFinalCondition("The finished started with #{workspace.objects.size} Energy Management objects.")
return true
@adhilton, this EMS code isn't too different from yours. The model this was used on has PlantComponent:TemperatureSource object on the demand supply side, and then cooling and heating water to air heat pumps on the demand side.
return false
end
if model.empty?
return false
end
model = model.get
string_objects = []
string_objects << "
Output:Variable,
string_objects << "
string_objects << "
string_objects << "
Ground_HX, !- Name
string_objects << "
Ground HX, !- Name
end
return true
@adhilton, this EMS code isn't too different from yours. The model this was used on has PlantComponent:TemperatureSource object on the supply side, and then cooling and heating water to air heat pumps on the demand side.
Here is the full run section of the measure that add's EMS code adds EMS. Code wasn't modeling infinite capacity. You could modify this to use the ES code from your answer.
return false
end
if model.empty?
return false
end
model = model.get
string_objects = []
string_objects << "
Output:Variable,
string_objects << "
string_objects << "
string_objects << "
Ground_HX, !- Name
string_objects << "
Ground HX, !- Name
end
return true
