When you load the model in the SketchUp Plugin, is it crashing there, or do you mean that even after re-saving in SketchUp you still get a crash in the measures tab in the stand alone OpenStudio application?
There is normally a directory next to your OSM file with the same name as your OSM file. I'm wondering if something correupted within that directory. Try this.
OpenStudio will re-create a clean copy of that directory when you open and re-save the OS. You will have to re-link the weather file, and re-add any measures. If this is the issue, then we may have you send us a zip of the OSM file and the bad directory so we can see why that happened.
