Further to @TaylorRoberts answer, you can set thickness of the glass in the material tab; you can set the thickness of the wall/sill/shading elements with a Window:FrameAndDivider object.
You can also use the Window and/or Optics programs to exercise total control of these elements and roll them up into a single element for inclusion in an OpenStudio model.
Updated Jul 17 2016
According to your additional comments, you don't know the thickness of the glazing, but you do know the SHGC/VLT/U info, and are merely evaluating the changes to window area and shading configuration. All the more reason to use the "Simple Glazing System" material type IMO; that material only requires these three inputs to describe the glazing performance. Then you can use measures to vary the WWR and shading configurations. Does this make sense?
