In E+, in order for the humidity to be controlled you need several things:
ZoneControl:Humidistat with humidity setpoint schedules.Humidifier:Steam:Electric object which must be added to an AirLoop. To you use this object you'll also need to put a SetpointManager:Humidity:Minimum, a SetpointManager:MultiZone:HumidityMinimum, or a SetpointManager:MultiZone:MinimumHumidityAverage on the Outlet Node of the Humidifier:Steam:Electric. Check out the Input-Output Reference to understand which one fits your situation.For dehumidification you need a system that can control humidity. Not all HVAC systems in E+ (or reality) control humidity explicitly. Here is a non-exhaustive list of some options:
ZoneHVAC:Dehumidifier:DXCoil:Cooling:Water with the Controller:WaterCoil 'Control Variable Field' set to 'TemperatureAndHumidityRatio'AirLoopHVAC:UnitarySyste with the 'Dehumidification Control Type' field set to 'CoolReheat' or 'Multimode'.
