Two formulas that I've used in the past: SEER approximately equal to 0.9 * EER EER = -0.02SEER^2 + 1.12SEER
The first is just from general googling, and was a rough consensus value between several sources. The second is from the eQuest mailing list forums. Using a SEER of 10 gives you 9 from the first, and 9.2 from the second.
past:
SEERSEER
EEREER
| 4 | No.4 Revision |
SEEREER approximately equal to 0.9 *EERSEER
