Suley, We are aware of the stability problems in the OpenStudio SketchUp Plugin, in particular with the intersect feature. We are currently using a native SketchUp method for this. It has issues in particular it seems with geometry that was initially imported from other cad tools, but I have also seen issues in native SketchUp geometry. We are developing native OpenStudio intersect methods that could then be used within SketchUp or as stand alone measures in the OpenStudio application. This should be both faster and more stable. We are also investigating other enhancements to creating and editing geometry in OpenStudio.
A few more things to avoid when using the Plugin to keep your model clean.
Things you should do when using the Plugin
One last thought on plenums. We have users making models 100 spaces on each floor. In that case a single plenum spanning the floor will have more than 200 surfaces and will have a negative impact on simulation run time. You could break them plenum into 4-5 separate plenums to speed up the run, but you can also make the plenum floor and ceiling a single solid surface with an adiabatic boundary condition. Then you can set the adjacent surfaces in spaces above and below to adiabatic. The surface search tools can help you do this, as well as assigning a construction for adiabatic (currently the default construction set doesn't include a construction for this boundary condition). If you expect significant temperature difference between the plenum and spaces this may not be a good idea.
Let me know if any other questions or issues come up.
David
Things you should do when using the PluginPlugin.
David
