Moving this as an answer for the record: It seems like a permission issue, on your temp folder. Can you go to %AppData%/Local/, right click on folder 'Temp', go to Security and make sure your user (Gorka) has Full control of this folder?
Alternatively, try to launch openstudio as administrator too.
Moving this as an answer for the record: It seems like a permission issue, on your temp folder. Can you go folder.
Go to %AppData%/Local/, %AppData%/Local/, right click on folder 'Temp', go to Security and make sure your current user (Gorka) has Full control of this folder?folder.
