All these tools can be used for be used for both sensitivity and optimization
Side note:
To some extent the Parametric Analysis Tool (OpenStudio PAT) can also be used, but it you have many cases it'll be tedious at best.
The EnergyPlus Parametric IDF objects can also be leveraged, as well as any scripting language you'd like.
Side note:
