I am pretty sure if you use the pre-cooling tab (not heat rejection) then the cooling towers takes care of the load before the chillers. Careful with the outdoor wetbulb temperature input though. Emir
I am pretty sure if you use the pre-cooling tab (not heat rejection) rejection), then the cooling towers takes take care of the load before the chillers. Careful with the outdoor wetbulb temperature input though.
Emir
