Let's get back to the (real-world) basics:
As far as how to model this type of systems in openstudio (or energyplus in general for that matter), it's been covered before here: you can either use a ZoneHVAC:PackagedTerminalHeatPump (or PTHP) or a VRF system: if your refrigerant flow is actually varying, it'll better capture the performance of your unit.
[1] There are also some PTAC units with steam coils, such as in the formerly Remington and now McQuay Type J and Type K, but I'm not sure you really encounter them much outside of NYC and maybe another couple of US cities in the North East that have a history of steam heating.
You also can encounter some PTAC with gas heating coils, but since that requires piping a gas line to each unit, I personally haven't seen them much.
![]() | 2 | No.2 Revision |
As far as how to model this type of systems in openstudio (or energyplus in general for that matter), it's been covered before here: on the same question I just linked: you can either use a ZoneHVAC:PackagedTerminalHeatPump (or PTHP) or a VRF system: if your refrigerant flow is actually varying, it'll better capture the performance of your unit.
