The measure you are looking at is an old EnergyPlus measure, that pre-dates PV support in OpenStudio. That is fine, it still works, but this post shows how to add PV directly in the SketchUp plugin .
In both cases PhotovoltaicPerformance:Simple. If you want to control inverter efficiency or add battery storage, you will have to write a new EnergyPlus measure. Battery storage isn't currently available in OpenStudio.
In both cases PhotovoltaicPerformance:Simple. is used. If you want to control inverter efficiency or add battery storage, you will have to write a new EnergyPlus measure. Battery storage isn't currently available in OpenStudio.
In both cases PhotovoltaicPerformance:Simple is used. used.
If you want to control change the inverter efficiency you can change this string or add battery storage, you will have to write a new EnergyPlus measure. expose an argument for it in the existing measure you are using.
ElectricLoadCenter:Inverter:Simple,
Simple Ideal Inverter, !- Name
pv_script always On, !- Availability Schedule Name
, !- Zone Name
0.0, !- Radiative Fraction
0.95; !- Inverter Efficiency
