Load your model using the ruby binding in a terminal or create a very simple measure in which you'll run this loop to remove all ZoneMixing objects
model.getZoneMixings.each do |mix|
mix.remove
end
Load your model using the ruby binding bindings in a terminal or create a very simple measure in which you'll run this loop to remove all ZoneMixing objects
mix.remove
end
Load your model using the ruby bindings in a terminal (see Optional - Install Ruby section in the introductory tutorial) or create a very simple measure in which you'll run this loop to remove all ZoneMixing objects
mix.remove
end
