Hi Andrea, you don't even need Macro (##include) to deal with construction/material or insulation thickness. All construction and material definitions can be put in the IDF model, as long as you name them differently. In the model, you assign a construction to a surface by referencing its name; so these assignments can be controlled with jEPlus parameters.
By the way, ##include within an included file will not work. However, you can put jEPlus parameters in the included files, and jEPlus will see them.
Regards,
Yi
