If you are delivering outside air with a gas-fired DOAS, then you have a gas baseline in the eyes of LEED.
If you have no gas heating, then you might be able to use the electric baseline:
Good luck!
If you are delivering outside air to your VRF spaces with a gas-fired DOAS, then you have a gas baseline in the eyes of LEED. LEED, period.
If you have no gas heating, heating serving those spaces, then you might be able to use the electric baseline:
Good luck!
