1 | initial version |
No, you can't change the fuel that HotWaterEquipment
uses. You could get the desired effect by instead using WaterUse:Equipment
objects to represent your hot water use. Assign them to a WaterUse:Connections
object connected to the demand side of a PlantLoop
with a WaterHeater:Mixed
with the 'FuelType' set to 'Electricity' on the supply side. E+ requires a pump on a PlantLoop
, but you can set the pump head to zero if your system doesn't actually have a pump.
