Here is a method to get the annual full load hours from a ScheduleRuleset. Add this to your measure.rb file:
# Get the annual full load hours from a ScheduleRuleset
def get_annual_full_load_hrs(sch_ruleset)
# Define the start and end date
year_start_date = OpenStudio::Date.new(OpenStudio::MonthOfYear.new("January"),1)
year_end_date = OpenStudio::Date.new(OpenStudio::MonthOfYear.new("December"),31)
# Get the ordered list of all the day schedules
# that are used by this schedule ruleset
day_schs = sch_ruleset.getDaySchedules(year_start_date, year_end_date)
# Get a 365-value array of which schedule is used on each day of the year,
day_schs_used_each_day = sch_ruleset.getActiveRuleIndices(year_start_date, year_end_date)
# Create a map that shows how many days each schedule is used
day_sch_freq = day_schs_used_each_day.group_by { |n| n }
# Loop through each of the schedules that is used, figure out the
# full load hours for that day, then multiply this by the number
# of days that day schedule applies and add this to the total.
annual_flh = 0
default_day_sch = sch_ruleset.defaultDaySchedule
day_sch_freq.each do |freq|
#puts freq.inspect
#exit
sch_index = freq[0]
number_of_days_sch_used = freq[1].size
# Get the day schedule at this index
day_sch = nil
if sch_index == -1 # If index = -1, this day uses the default day schedule (not a rule)
day_sch = default_day_sch
else
day_sch = day_schs[sch_index]
end
# Determine the full load hours for just one day
daily_flh = 0
day_sch.values.each do |val|
daily_flh += val
end
# Warn if the daily flh is more than 24,
# which would indicate that this isn't a
# fractional schedule.
if daily_flh > 24
return 0
end
# Multiply the daily flh by the number
# of days this schedule is used per year
# and add this to the overall total
annual_flh += daily_flh * number_of_days_sch_used
end
return annual_flh
end
Here is how you'd use it:
annual_flh = get_annual_full_load_hrs(sch_ruleset)
And once you know the annual_flh, the target peak flow rate = desired annual total / annual_flh
