This warning means the simulation has determined that five surfaces in your model have centroids that lie below the building ground plane (Z = 0), and is letting you know that the exterior heat transfer of those surfaces in the simulation will not be affected by wind speed, and the exterior surface temperature will be assumed to be at ground level (the 9.740E-003 is a factor that corrects for the height of the weather station above ground).
