Here is a measure where you can pick an airloop or plant loop, specify whether you also want demand nodes (it'll include the supply nodes by default) and to pick which output variables you do want and it'll add them for all the requested nodes: BCL
Here is a measure where you can pick an airloop or plant loop, specify whether you also want demand nodes (it'll include the supply nodes by default) and to pick which output variables and the frequency you do want and it'll add them for all the requested nodes: BCL
