I've finally came to add this measure to shrink windows around their centroid on the BCL: you can find it here.
Note that it should always work for shrinking windows, but if you use it to increase the size of the windows, it could theoretically result in windows that extend from their base surface, so just be aware of that.
I've finally came to add this OpenStudio measure to shrink windows around their centroid on the BCL: you can find it here.
