Before asking such questions, make sure you check the following resources:
mymodel\run\5-EnergyPlus\eplusout.rdd | 2 | No.2 Revision |
Coil:Cooling:DX:SingleSpeed objects for example, this section is pretty limpid.mymodel\run\5-EnergyPlus\eplusout.rddNow, you won't find this at the zone level, as highlighted in the I/O reference guide here there is no output variable for zone latent load.
You'll find this at the HVAC level. I already showed you which one you need in the case of a Coil:Cooling:DX:SingleSpeed for example, here is the same if you're using ZoneHVAC:IdealLoadsAirSystem
