I saw your advice Urado, and it worked... However, when I run the simulation (after solving some errors) the results are blank, is like if my system is offline...
https://unmethours.com/upfiles/14643647165708003.png
As you can see, theres no Heating or Cooling loads, what am I doing wrong?
I have my system represented as the following pictures
https://unmethours.com/upfiles/14643648684645729.png https://unmethours.com/upfiles/14643648789757786.png
