Great, thanks. OK so I ran your model here on OpenStudio 1.11.1 and it ran fine. If possible, I'd recommend getting the latest "iteration release" (currently 1.11.3) which you can grab here. If there's any way to put your entire run directory (from the failure) on Dropbox , I'd love to take a look at the logs. If not, no big deal, just grab a newer OS release and try again. Should work for ya on 1.11 or greater.
Thankyou for your help solution. After installed the Lastest OpenStudio release (1.11.3), the simulation run well (but Still with some warning). But now i can see the result, so i can sleep well tonight hahaha.
This is my Resultlog, i hope you may see my result simulation. Maybe you can give another advice to my model project. https://www.dropbox.com/s/d9tv50rzm0dzahp/Source%20Code%20-%20Finish%20with%20Warning.txt?dl=0
Thanks alot
