This is because thermalZone.airLoopHVACTerminal returns an optional.
Try this:
thermalZones = model.getThermalZones
thermalZones.each do |thermalZone|
supplyTerminal = thermalZone.airLoopHVACTerminal
if supplyTerminal.empty?
runner.registerInfo("Cannot find an airloop terminal for #{thermalZone.name}")
else
supplyTerminal = supplyTerminal.get
runner.registerInfo("For '#{thermalZone.name}' the supply terminal '#{supplyTerminal}' was found.")
end
end
Try this:
thermalZones.each model.getThermalZones.each do |thermalZone|
|zone|
zone.airLoopHVACTerminal
else
runner.registerInfo("For '#{thermalZone.name}' the supply terminal '#{supplyTerminal}' '#{supplyTerminal.name}' was found.")
end
end
This is because thermalZone.airLoopHVACTerminal OpenStudio::Model::ThermalZone::airLoopHVACTerminal() returns an optional.optional HVACComponent, see SDK doc. You have to get it first.
Try this:
model.getThermalZones.each do |zone|
# this returns an optional HVACComponent
supplyTerminal = zone.airLoopHVACTerminal
else
runner.registerInfo("For '#{thermalZone.name}' the supply terminal '#{supplyTerminal.name}' was found.")
end
end
Like I said supplyTerminal, even after ".get" will be an HVACComponent, not an actual object such as OpenStudio::Model::AirTerminalSingleDuctUncontrolled for example. If you need to work with the actual underlying object, you'll have to cast it into what it's really.
The clean way is to use to_XXXX method, but you have to test potentially a lot of cases...
if supplyTerminal.to_AirTerminalSingleDuctUncontrolled.is_initialized
supplyTerminal = supplyTerminal.to_AirTerminalSingleDuctUncontrolled.get
elsif supplyTerminal.to_AirTerminalSingleDuctVAVNoReheat.is_initialized
supplyTerminal = supplyTerminal.to_AirTerminalSingleDuctVAVNoReheat.get
else
runner.registerInfo("I don't know what this object is because there are too many possible ones!")
end
You want the dirty way? I knew it! But I shall not be liable for any problems you might get :)
Anyways, just add this method to the class ModelObject...
# Extend ModelObject class to add a to_actual_object method
# Casts a ModelObject into what it actually is (OS:Node for example...)
class OpenStudio::Model::ModelObject
def to_actual_object
obj_type = self.iddObjectType.valueName
obj_type_name = obj_type.gsub('OS_','').gsub('_','')
method_name = "to_#{obj_type_name}"
if self.respond_to?(method_name)
actual_thing = self.method(method_name).call
if !actual_thing.empty?
return actual_thing.get
end
end
return false
end
end
Then you can do supplyTerminal = supplyTerminal.to_actual_object
It'll work with anything, since everything in OpenStudio::Model is after all a ModelObject: ModelObject instances, HVACComponent, even objects such as AirTerminalSingleDuctVAVNoReheat themselves (though that's completely pointless)
| 4 | No.4 Revision |
This is because OpenStudio::Model::ThermalZone::airLoopHVACTerminal() returns an optional HVACComponent, see SDK doc. You have to get it first.
Try this:
else
end
end
else
end
end
end
return false
end
end
