See this previous question for code and instructions to write a quick measure that will display results in IP units. The measure also makes EnergyPlus output delimited, HMTL, and XML result files. To view your results I'd suggest taking a look at DView.
![]() | 2 | No.2 Revision |
![]() | 3 | No.3 Revision |
See this previous question for code and instructions to write a quick measure that will display results in IP units. The measure also makes EnergyPlus output delimited, HMTL, and XML result files. To view your results I'd suggest taking a look at DView. which is nice for viewing 8760 data in CSV format.
![]() | 4 | No.4 Revision |
To view your results I'd suggest taking a look at DView which is nice for viewing 8760 data in CSV format.
![]() | 5 | No.5 Revision |
![]() | 6 | No.6 Revision |
See this question for code and instructions to write a quick measure that will display results in IP units. The measure also makes EnergyPlus output delimited, HMTL, and XML result files.
OpenStudio doesn't create the OutputVariable CSV file during an EnergyPlus run so you'll have to run the out.idf
file through EnergyPlus to create it. To view your results these I'd suggest taking a look at DView which is nice for viewing 8760 data in CSV format.
![]() | 7 | No.7 Revision |
OpenStudio doesn't create the OutputVariable CSV file during an EnergyPlus run so you'll have to but you can run the out.idf
file through EnergyPlus to create it. To view these I'd suggest taking a look at DView which is nice for viewing 8760 data in CSV format.
