You should have U-value report only for certain constructions (center of glazings) and not for every window in the building. U-value of the window plus frame is not calculated, however, I would need to check if that is actually not part of eio file.
You should have U-value report only for certain constructions (center of glazings) and not for every window in the building. U-value of the a window plus frame is not calculated, reported (and not calculated as such), however, I would need to check if that report is actually not part of eio file.file, but at a moment I am 99.99% sure that it is not.
Note that U-value of COG is calculated by using standard NFRC conditions and not conditions from weather file that are used in simulation.
