My 'Sec-CW Loop supply Temp is schedule' for 7.5 C, Which is from TES tank with setpoint Temp of 7.5 C as well. I removed the Minimum Actuated Flow or 0 to nil Reduced ThermalStorage:ChilledWAter:Stratified: Deadband Temp Diff from 3.5 ->2.5 ( i think this did not help in anyway but I did not try to see the impact)
Added Cooling coil inlet & outlet node names to SetpointManager:MixedAir, Cooling Coil ( this was blank earlier)
This removed the warning
Now back to figuring the SImHVAC error that I am getting around 35 times with weather file simulation days.
