Feel free to adapt the following code, it'll give you some training on measures too!
# Find the north walls, with a big tolerance here.
between_deg = -25
until_deg = 25
# Conversions to SI units
between_rad = OpenStudio::convert(between_deg,"deg","rad").get
until_rad = OpenStudio::convert(until_deg,"deg","rad").get
# Construction: adapt to grep the construction you actually need
construction = model.getConstructionByName("North Construction").get
model.getSurfaces.each do |surface|
# Find exterior walls only
next if surface.outsideBoundaryCondition != "Outdoors"
next if surface.surfaceType != "Wall"
# Filter on azimuth: OpenStudio works CLOCKWISE (different from classic trigonometry), and returns it in radians
# Also doesn't take care of the Building North Axis, it'll be in your original drawing (that's usually easier anyways)
# If you want the north wall: 0, east: Pi/2, south: Pi , west: 3*Pi/2
# Filter on azimuth
azimuth = surface.azimuth
# Case where start point was negative
if between_rad > until_rad
next if (azimuth > until_rad) && (azimuth < between_rad)
else
next if (azimuth < between_rad) || (azimuth > until_rad)
end
#surface.setConstruction(construction)
puts "Assigned construction to #{surface.name} which has an azimuth of #{OpenStudio::convert(azimuth,"rad","deg").get} degrees"
end
Feel free to adapt the following code, it'll give you some training on measures too!too! I'd personally not create an actual measure for this, I'd just open a terminal window and do some interactive ruby on my model, but that's just me.
between_deg = -25
until_deg = 25
# Filter on azimuth
else
end
end
Feel free to adapt the following code, it'll give you some training on measures too! I'd personally not create an actual measure for this, I'd just open a terminal window and do some interactive ruby on my model, but that's just me.
between_deg = -25
until_deg = 25
# Filter on azimuth
else
end
end
| 4 | No.4 Revision |
between_deg = -25
until_deg = 25
# Filter on azimuth
else
end
# Assign the construction to the surface
end
| 5 | No.5 Revision |
# If interactive, load model
path = 'C:\mymodel.osm'
translator = OpenStudio::OSVersion::VersionTranslator.new
ospath = OpenStudio::Path.new(path)
model = translator.loadModel(ospath)
if model.empty?
raise "Path #{path} is not a valid path to an OpenStudio Model"
else
model = model.get
end
between_deg = -25
until_deg = 25
# Filter on azimuth
else
end
end
