When you assign a Space Type from the OpenStudio library, you are putting in defaults for:
  • Lighting (LPD) and lighting schedule
  • Plug loads and plug loads schedule
  • Occupants, occupancy schedule, and occupant activity (load) schedule
  • Minimum ventilation (OA) requirements
  • Infiltration
You want to get these right because these loads can vary greatly depending on the space type.
You can get more space types (from other building types) 2 ways:
SketchUp plugin:
  1. Plugins>OpenStudio Plugin>OpenStudio User Scripts>On Demand Template Generators>Space Type and Construction Set Wizard
  2. Pick the building type, climate zone, and vintage of interest (note that different building types include different space types).
  3. Click OK>your model should now have a bunch more space types to pick from
Note that you can do this many times to get space types from many different templates into your model.
OpenStudio Application:
  1. File>Load Library'
  2. Pick the building type of interest
  3. You should now have a bunch more space types in "My Library" in the Right Column to pick from.
