Your Controller Water Coil 2 applies to a cooling coil and is correctly set to be Reverse Action, so that's not the problem.
The problem is :
** ~~~ ** Controller temperature setpoint = 15.82 [C]
** ~~~ ** Controller sensed temperature = 16.13 [C]
Your loop temperature is higher than the setpoint, that's what you should investigate.
